HP Elitebook 8470p power troubleshooting
I have an HP Elitebook 8470p. It works fine when plugged in, but as soon as I remove the charger it dies. The battery reads as being present when it is on and at 79%. To test it, I got a new battery and thought maybe the old one just went bad. I put in the new battery and still does not turn on. Seems like an issue with receiving power from the battery, regardless of which. What should I try next?
EDIT: SOLVED. Removed the charger and battery. Held down the power button for 30 seconds. Reseated the battery…it now works. Thanks to the discord for the help
