So I've been working on developing a way to parse a complex input file. So far I've got all the values read in as strings and stored in a dynamically sized vector. Take a look:
#include <iostream>
#include <fstream>
#include <vector>
#include <algorithm>
int lineCount = 0;
string buffer = "";
std::vector<string> fileDump;
ifstream in(argv[1]);
if(!in.good()){
cout << "Can't open file, or no file has been passed via arguments!" << endl;
} else {
cout << "File opened, begin reading...";
do {
getline( in, buffer );
fileDump.push_back(buffer);
lineCount++;
while(in.peek() != EOF);
in.close();
cout << "...complete!" << endl << lineCount << " line(s) read, and " << int(fileDump.size()) << " values stored." << endl;
//lambda expression to step thru the vector
for_each( fileDump.begin(),
fileDump.end(),
[] (string s){
//cout << s << endl;
//work in progress
And here is my header file:
#ifndef CLASSES_H
#define CLASSES_H
#include <iostream>
#include <fstream>
#include <string>
class Assignment
private:
std::string assignmentType;
int currentNumberOfGrades;
int totalNumberOfGrades;
double percentOfFinalGrade;
double* allGrades;
public:
Assignment();
Assignment( std::string, int, int, double );
std::string getAssignmentType();
int getCurrentNumberOfGrades();
int getTotalNumberOfGrades();
double* getAllGradesArray();
double getPercentOfFinalGrade();
void setAssignmentType( std::string );
void setCurrentNumberOfGrades( int );
void setAllGradesArray( int );
void setTotalNumberOfGrades( int );
void setPercentOfFinalGrade( double );
void updateGradesArray();
#endif
And here is what an input file looks like:
3 <--- Types
Lab <--- Type of description
4 <--- Current Grade Count(bellow are the grades)
100 <--- Grade 1, and so on for the next...
90
70
88
10 <--- Total
10.0 <--- Weighted percentage
<--- Separator
Quiz
3
89
75
92
5
15.0
Exam
1
89
2
30.0
*Only a sample, the professor will run with a file that follows the same format but will vary in length and have different data.
I've tested it and it runs just fine for storing all the values I need. However, the values are stored all as strings. I am not all that well versed in vectors and have been reading the C++ reference about them. What I would like to know if there was an easy way to parse out my ints / store them as ints. Think I need to run some code to check them as I read them in, or do vectors have built in functions for parsing?
2) There are many ways to convert strings to int...
sscanf(input, "%d", &number); // old... not used anymore
cin >> dec >> myInt; // cpp new way with streams
myInt = atoi(c-string); // old... not used anymore
myInt = stoi(string); // uses string class.
3) I'd have to look it up but I'm pretty sure there's a command to read in the whole file so you don't need that loop. Not sure atm though.
for my class we have been building a terminal game in C and so we are going into C++ so we had to interface C and C++. My next HW I have to write code to read txt files to setup a game.
It's a real shame they don't teach C++ before C. There's so much C++ has to offer but to really wrap your head around it you need to not think about C.
If you're gonna use function pointers to do that interface... check out std::function instead. It's amazing. It lets you get pointers to member functions.
Well we are converting the whole project over to C++ now but I simply used void pointers to hold the classes in C and then had a function that used extern "C" {} to declare functions for C and C++ and pass the objects as a parameter and then cast it back to an object.
Since they are using functions as objects is it possible to do functional programming with that?
Also I have found I like C and C++ much better than Java and I kind of like assembly so I was wondering how one would get started in embedded systems since your description says you do that?
BS in computer science, I know you might say that I should switch to EE or COMPE for embedded stuff but I also want to go into studies on artificial intelligence, at the moment I just want to start some side project involving embedded systems to play around with it.
I used to go to IEEE here but all that would happen is either they would talk about how great they were or a company would give their speech. I just go to our local computer science club now. I also had a bit of a falling out with one of their cabinet members because he was kind of a prick in a short story lol. I am better at self teaching anyway.
I am also in a computer architecture class where we have had to write the states of a finite state machine with a given architecture to do some type of operation that would control the data path of a simple architecture. With that we have learned some assembly as well. On top of that I had to take a course on digital design or digital logic where I had to design a random number generator. Finally as you know I am in a C and C++ course. I think these are relevant to embedded systems. https://github.com/sdrafahl/Hardware-Random-Number-Generator
If I wanted to buy something cheap to do a project where would you recommend I look?
How's your code in terms of what? If you just want something that works then that's fine. If you want something that's highly optimized... no it's not good.
