http://pcpartpicker.com/user/jsheckler/saved/3lFP
modded a few builds together. if this all looks good to you guys i will be buying all of this tonight!! thanks a ton for the support. the keyboard and mouse are only there because i'm tired of my shitty ones
thanks for the help and support guys!! let me know if anything needs changing!
Looks good to me.
Nice keyboard. I really want one of them K70s.
Anyone else wanna weigh in on this? Ordered the keyboard and mouse so far but I'm scared to order more:-)
Is that power supply big enough? I won't be overclocking. Do I need a cpu cooler or will the stock work? Case fans? Stock or do I need better ones?
Looks good. Why won't you be overclocking?
If you're dead set against it I'd suggest looking into an ivy bridge build with the i5-3350p and b75 mobo. You'll save almost $100 and you can turn that into an SSD.
But that's only if you will absolutely NOT overclock your CPU OR if you primarily play starcraft or an MMO like WoW or GW2.
The PSU is fine, but I'd still suggest looking into an XFX or Seasonic unit at that price point. If you're only going to run the single GPU then 700w is overkill.
You can pick up case fans and other things later. The case should come with one at the least.
For the CPU cooler - get at least a cooler master 212. They're inexpensive and work fine. That's only if you plan to OC the 8350 at some point. Which you should :)
That power supply is more than adequate, and the stock cooler is fine if you aren't overclocking. Also the case comes with two fans so you are fine there too.
I have the same processor, motherboard, keyboard and mouse and i love all of them. I'd recommend getting a gtx 770 4gb for $30-$40 less than the 280x at that price point. Here's the 770 i got: http://pcpartpicker.com/part/gigabyte-video-card-gvn770oc4gd Its wisher quiet and I have never seen it go over 67 degrees with the graphics card and cpu at 100% load
I wanna use this build for lots of games. Not really a huge mmo guy. But ESO looks cool. Lately I've been into chivalry and far cry 3. I definitely want the 8 cores on the amd processor for newer titles that will supposedly utilize them. Like Watchdogs etc.
I'm not AGAINST overclocking.. It's just that I've never done it before. If i feel like the system can benefit from it I'll for sure give it a shot.
I want to get the larger power supply because i want this build to be able to evolve when it needs to. Know what i mean?
Your motherboard supports up to 2000MHz RAM it looks like, I'd suggest going with that if your budget allows.
Also, thinking of swapping my 280x to the gigabyte 770 with 4gb of vram.
Looking at the charts? They perform close enough. And the 280x is jacked up because of bitcoin mining right now.
