There are an abundance of computer cases on the market with more options than you can possibly imagine. Building a PC can sometimes just be something practical with no real care for anything other than a cost/ performance ratio. Other times however it can be an expression of creativity and fun. The latter is what I am about to do and wanted some simple opinions on what motivates your choice on picking a new case.
(I am leaning toward a CaseLabs case, but for the price maybe I am just being ridiculous)
The way you pick your case is by aesthetics and sound reduction mainly, you should always do some research and look at reviews and sound tests before buying a case, most expensive cases aren't worth the money.
Also some cases can only hold certain motherboards so make sure your case isn't really small because it is likely it only supports mini ITX.
What i usually do is set a budget, then I make a list of needs (Ex. if the case will support my mobos size) and wants (ex. removable HDD cages) and round it down. Once all my needs are covered I round down the rest of the cases I've selected to my most wanted wants for a case (side window for example) and then I read reviews of whatever few cases I have left on my list and that helps me decide which case I want.
Its a bit of work but it helps you find the best case for your needs/wants and budget.
It depends on what I'm going for in a build. I'm usually not very concerned about portability, so I tend toward big cases with lots of room for components and airflow. I've been using a Cooler Master HAF-X with my main PC for a little over a year now, and aside from a few minor gripes, I'm very happy with it. It also looks pretty great (IMO).
I myself rack mount everything, my current gaming pc is no different and is in a 4u rack mount enclosure and is also water cooled with a x2 240 radiator that i cut into the top panel. Hard to fit.. sure it was but I needed something that could be stashed in a rack reguardless. I run anywhere from 3-7 pc/servers at a time and everything is on the other side of a well insulated wall from me, noise has never been a issue unless of course I'm in there doing a bit of maintenance.
Start with budget for a case then go from there. I usually go for full-ATX for future upgrades. I like corsairs Obsidian series cases. I have the 750D right now and good god it fucking looks gorgeous!
I would have gone with the 900D but that was beyond my budget. If I ever get $1K as a budget for a case, I plan on getting a case labs.. I mean just look at this thing!:
Features, features, features. I am a function over form kind of person so I like cases that have plenty of useful features. I choose my case, the Phanteks Enthoo Pro, because for its price it had the best feature loadout of any of case in its price point ($100) (better than even the "untouchable" define r4). So the features I chose this case for were:
Water cooling support (lots of radiator mounting options, dedicated reservoir mounting plate plus another res mount by the PCI-E brackets, and a place to mount an optional universal pump bracket)
Velcro cable management straps all over the place
Comes with a fan hub
PSU shroud
Its a really top notch and luxury feeling case, even the screws come in a plastic divider box instead of little zip-lock bags
For me, it's about sound isolation and design. My current specs tend to run pretty cool (G3258, Gigabyte R9 270X), not to mention I want to get a CM Nepton 280L which will probably be complete overkill (but hey, I'll be able to overclock like crazy). At first I thought about NZXT H440, which I hear is good for water-cooling not to mention has crazy foam thickness and a simple yet beautiful look to it. However, I think I might go for the Aerocool DS Cube because apparently it's rather silent, it can fit my 297mm graphics card (surprising for a mATX case), and the motherboard is flat, which I really like - it makes much more sense to me than having it mounted sideways. Plus, it has a 3.5" and a 5.25" bay which the H440 lacks, not to mention if you finagle it, you can fit a 280mm radiator. (Did I mention this is a mATX case?)
That said, research is most important. Look at what you want to have and what your options are for those. If you're going for a color scheme, get a case with a window. Do you need a lot space for air or a lot of hard drives and whatnot? On the other hand, do you have enthusiast-consumer grade tastes (i.e. Z97 over X99)? Anything bigger than mid-tower ATX is probably overkill unless you really like the aesthetic. Or, if you're really adventurous, you can try to build your own. Outside of that, it's just wondering whether you'll really need an ODD that comes with that bigger black case, or get the brushed-aluminum finish case.
It depends on the type of build you are looking for. In my case (no pun intended), small, portable, elegant, out-of-the-way, and sufficient ending up being my theme.
It seemed to suit my needs and did it while looking stylish and being functionally tiny.
This doesn't mean that I hate large cases though; They have a place in the market. I will eventually build another PC using a larger case for expansion purposes, but as of now, I am content with my handsome little LAN rig.
