How will a 7770 perform with this?
Hey guys,
How do you think a 7770 will perform on this system on games such as bf4, ps2, arma 2&3 and other games in general?
http://pcpartpicker.com/p/2IurW
I do plan to upgrade to a 270x but in the meantime i still need to get a better cooler a new keyboard a powerline kit and a surge protector so the 7770 will have to do for now.
Performance depends on the resolution you intend to play at eg 1080p with medium to high settings you'll be lucky to see 30fps.
For the price of a 7770 one could surely source a good 2nd hand gtx580/70, 6970, gtx660 or the like. If you already have the 7770 then you have the option of throwing in another 7770 later on for some crossfire goodness.
i think the 7770 will be fine unless you are obsessive about staying away from the lower end of the game detail spectrum, for the mean time all the games will go fine on low-med but when you upgrade you will love it that you did. (i word everything retardedly so don't judge hahaaa)
+1 the FX6300 with Asus M5A97 R2.0 is a very decent combo. But you can cheap out on ram. like Pop shows above, the extra money you save, you can trow that in a better GPU, like a 7870. thats realy worth it. ☺
I have the 7790 that is only a bit better and the only games I've had to put on lower than high are Crysis (2+3) and Battlefield 4 (haven't tried 3 with this card). The Metro games probably will have to be lower too. But there's so many games that will run fine on high or even ultra, just depends on what you play and/or how old the game is. (If DICE would fix BF4 I could even run it on high, but meh, EADICE failure, the framedrops are not worth it)
Lately there haven't been many good games out so I haven't been able to test more. But for the price it's good enough imo.
I don't think upgrading from a 7770 to a R9 270 would be a good investment, it might actually be worth picking up a last gen (architecture wise) card (e.g. GTX580). I know here in the UK I can get them used for about £110 whereas the better 2GB 7770s are £105.
I bought the ram already and it was has went up in price since, it was one of the cheapest ones i could find. but since then it has gone up, but thanks
I know that arma is more cpu based so how do you think itll perform there, and yes at 1080p
Like i said it was cheaper when i ordered it.
Im might save up for a 280x if not id probably go with a 7870
