How well is my wishlist for my PC?
Okay, so I use newegg for shopping computer hardware and I am a novice compared to a novice on picking PC parts(well not really, i know the basics and all, but by no means am i an expert), I don't want to go outlandish on price but i also want this to be able to play (most) games in 1080p on medium settings, so here's my list
Case: Antec Three Hundred Black Steel ATX Mid Tower Case
Motherboard: ASRock  Fatal1ty Z97 Killer LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Graphics Card: ASUS GTX750TI-OC-2GD5 GeForce GTX 750 Ti 2Gb 128-Bit GDDR5 PCI Express 3.0 HDCP Ready Video Card
Power Supply:  Antec Earthwatts EA-650 GREEN 650W ATX12V v2.3 SLI Ready CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply - Intel Haswell fully compatible
Processor: AMD Athlon X2 370K Richland Dual-Core 4.0GHz Socket FM2 65W Desktop Processor AD670KOKHLBOX
RAM: CORSAIR Vengance 16GB (2 x 8GB) 240-pin DDR 3 SDRAM DDR3 1600 desktop Memory Model CMZ46GX3M2A1600C10R
Hard Disc Drive (Solid States are too expensive): Western Digital WD Blue WD10EZEX 1TB 7200 RPM 64 MB Cache SATA 6Gb/s 3.5" Internal Hard Drive Bare Drive - OEM
I want you to be critical (But be nice please) and tell me places where i can save money or improve preformance for a similar price (~20% higher price) or less
This setup totals just under 700 USD
Please use PCPartPicker next time.
No offense but this build is a mess. You're using Intel motherboards with an AMD CPU. A low powered GPU, way too much RAM...
Here. Going off a budget of $700.
http://pcpartpicker.com/p/K8bM23
That should max most games at 1080p and will be okay at 1440p. You even get an SSD.
Looks good +1
good but,  ram and gpu are sold out.  psu cx600 don't think its from a good oem.
http://pcpartpicker.com/p/6XpcVn
That is a pretty crappy motherboard and the CX series from Corsair are good. Have used dozens fo them. They are fine. Better than XFXs...
They're alright, but XFX power supplies have Seasonic as their OEM, and use all Japanese capacitors.
I'd take a XFX over a Corsair CX power supply any day of the week.
Holy cow, Captain COW!
Me thinks this is a trololol topic.
+1
I wish I would have went with a XFX PSU over my Corsair CX600. The Corsair gets the job done, but I'd feel better knowing I had a more reliable PSU delivering raw electricity to my precious PC components.
Thank you Sir, I read in a magazine, if i used 16 Gb of RAM i would have plenty for a LONG time, and i didnt know mixing Intel and AMD was a no-no, and i did everything i could to keep it in my buget of under $700, so since my video card was the last part i searched up, i had to make a sacrifice, Thank you Sir again, I'm really glad i hadnt ordered this yet =D
I'll be honest here and say that you probably shouldn't be trying to be building a PC atm, you will probably run into a lot of problems with the amount of knowledge you have. No offence of course (i was like you once) but wise advice.
