Ubuntu 16.04.3 is out. Updateing the Kernel to 4.10.
Upgrading is really easy -
sudo apt install --install-recommends linux-generic-hwe-16.04 xserver-xorg-hwe-16.04
If you installed using the Ubuntu 16.04.2 LTS image you’ll automatically receive the new HWE via the Software Updater.
I was running the first instance of 16.04 so needed to update. I’ve update both my machines this was with no problems. This update fixes a load for bugs and has alot of hardware support updates.
https://wiki.ubuntu.com/XenialXerus/ReleaseNotes/ChangeSummary/16.04.3
You can check what Kernel you are running with -
uname -r
Source comes from OMG Ubuntu
