How do you install and make sure mesa 19.3 + loads correctly?
Upgrading Mesa has always seemed like a vague and unclear topic with a lot different examples being given on the process. I’m sure this is because all distro’s have they’re own way of doing things, but how do you force upgrade to a newer edition of mesa when you gpu in unstable otherwise?
I have no idea how it works on Mint but I had similar problems on it. Only way I could get my monitor to at least work properly was to install the driver offered by amd on their site, which unfortunately pretty much broke everything else up to a point where I had to switch distros.
This was on kernel 5.0 on mint 19.2 and I was kind of hoping kernel 5.3 would’ve fixed it already but I guess not.
I haven’t had any issues with it on open suse since kernel 5.3 and mesa 19.2, so no idea what the issue is or why the drivers are not properly installed on mint. I hope it gets solved for Mint 20 at least.
Kernel 5.3.x on fedora 30 made my rx5700xt mostly useable, and kernel 5.4.x on f30 was even better, but until I upgraded to fedora 31 (same 5.4.x kernel at that moment) all my issues didn’t go away.
The point of my story was to provide hope for the coming version of mint.
From what I saw on Phoronix 5.4 kernel is where tou need to be at the very least.
Also I believe Oibaf is based on Ubuntu generated debs which may be part of your issues. I am a Debian user and basically bit the bullet to compile from scratch and use checkinstall to install the resultant packages as debs. Oibaf broke my Debian systems a few times.
But that was in the SI and CI days. I am still running my Bonaire card from 2013.
Do you have enough experience to compile from scratch? Going this route may show you if you are missing a dependency. You would most likely find this out during the ./configure stage.
No I don’t currently no how to compile from scratch. I’ve installed make files in the past, but the mesa install seems complicated and they’re site doesn’t give a very good tutorial.
Wouldn’t mind learning as being able to upgrade mesa as desired would be nice.
