The only reason I spend like 5+ hours organizing all my music on foobar was to have it all nice and neat on my phone, not my computer, don't really care how it is on my computer cause I generally just watch it on youtube anyways.
And you spent 5+ hours organizing all your music in FooBar only to have it on your phone WITHOUT finding this information out beforehand?
Well, anyways, what I do is just all of my music from each FooBar playlist and drop it into a folder of the same name in my phone, then when I'm adding music to a playlist I just select all from that folder. As for Track Information, hopefully you have all your tags updated. It's not the best, nor the fastest method possible but It works for me. (Only downside is every time you add music to your Library in FooBar you must manually add it to your phone.)
It's a few years old and not for your phone but It's better than nothing. Past that I turned up empty.
If anyone else has anything on this, I would also be interested. Hey I would even pay for a component / android app for simplifying the process, just saying.
He's talking like sync all your playlists with your phone just by plugging it into the computer. Any changes you make on your FooBar playlists will automatically be updated on your phone the next time you plug it in.
By sync I simply meant adding the music onto my phone. The way my music folder is organised is as follows:
Tracks->[artist]->[album name]->song
can I just put the tracks folder into the "music" folder on my phone? I thought I could only put the songs themselves in the folder. If that is the case then since there is no "collapse folder" option on windows 7 it would take extremely long to do that way. Even if there was, it would be incredibly long.
You can name music folder any way you like and you can put it anywhere on the storage, the phone will index it and you'll be able to play it with any music player.
I've tried using BitTorrent Sync to sync the music onto my phone, and it's onto my phone and I can play it but it's kind of tedious.
Currently the music is as follows: Music->[artist]->[album]->[song file]
The only way I can listen to it right now is by going into the bittorrent sync app, and clicking on the .mp3 file I downloaded. It doesn't show up in my music app which is the default "walkman" app from sony.
Just tried NexMusic, at the bottom part where there's the pause, previous and next buttons the music is there and goes through it randomly but in songs/albums/artists there is nothing other than "To copy music from your computer to your device, use a USB cable."
