Install the Pop!OS nvidia version.
Install snapd:
sudo apt install snapd
Install obs-snap version.
sudo snap install obs-studio
finally install some extra components:
sudo snap connect obs-studio:removable-media
sudo snap connect obs-studio:camera
You will need to reboot before obs shows up in your program list.
After this, you can basically just set it up.
I use some weird sound hardware so I had some oddball things I had to do to get that set up in OBS.
This was the fastest and easiest setup I’ve done for an ‘out of the box’ distro. I can still get an install up faster in Arch, but this is because I’ve already done the hard work and built a custom set of scripts.
I have tested Ubuntu, Kubuntu, Fedora, Mint, and Ubuntu studio, none have come close to the ease of this setup.
Full disclosure, I found this blog post which got me most of the way:
https://jsebean.com/2019/04/nvenc-on-obs-studio-on-poposubuntu-1904
I have done a couple of test records and ran a test stream tonight successfully.
I will be working on adding in notification support soon as I have read about a few tools that do this through plugins. I just want to review the code before using it.
