So I bought a 2011 13" MacBook Pro at a University surplus store. I purchased this for my mom, thinking all it would need is a hard-drive. I threw an SSD in it, installed MacOS, and then realized to my dismay that it won't charge and the battery holds no charge at all. Now I know a new battery is only $30 on Amazon, and I do have on ordered, but I'd like to solve this issue if I can.
The laptop sat in storage, probably completely dead, and probably for months. As such, the battery has only 525 cycles on it but is indicating that it must be replaced. Upon clicking the little button next to the battery indicator, the entire row of charge indicator LEDs blinks red 5 times. On boot, the ~1/3" long LED on the front of the laptop blinks 5 times as well. From what I gather, this indicates that the battery must be replaced. When plugged in, the LED on the charger glows green.
Things I've tried: 1) Disconnecting the battery, waiting 30 seconds, reconnecting. 2) Disconnecting the battery and indicator connection, waiting 30 seconds, reconnecting. 3) DIsconnecting the battery/indicator connection, holding the power button for 10-15 seconds, reconnecting. 4) DIsconnecting the battery/indicator connection, holding the power button + command + control for 10-15 seconds, reconnecting. 5) Leaving the charger connected overnight.
Is there anything else I can try to get this thing to live again? Is this a physical, electrical issue and a truly dead pack or just some BS software thing that Apple has built in to disallow charging?
Have you ran the laptop with out the battery installed? Also if it isn't the battery the most likely issue is the connection on the logic board itself. One of the connections should lead to a sensor that detects the condition of the battery installed and that sensor may have shit the bed.
Yeah, that's where I started. Is there any way in software, MacOS (or BIOS, I guess?) to "reset" the battery status and let the computer try to re-assess the situation?
I actually may not have done a PRAM reset. I thought I had, but that's apparently separate from the SMC reset. I shall try both running without the battery and doing a formal PRAM reset.
A battery is already ordered and on the way. The laptop was bought at University surplus, so it can't be returned, but I could part it out for way more than what I paid for it. I could also try to find a replacement sensor.
