How to recycle own components?
I have a number of things I need to fix right now. A few GPU’s, a ras pi V1, etc etc.
Thing is I’m not very good at removing components from other boards, nor am I sure my multimeter works. Its some cheap chinese AstroAI thing but I see other people online use them so idk what gives.
What do you guys usually look for components on? Do you have good results with repairs? What tools do you use? Can I get away with a half assed soldering station made by ryobi?
thx lmk
In addition to an iron I would also recommend a hot air station for reworking boards. There are some cheapo chinese all-in-one stations on Amazon. I’d recommend trying a $90-$150 kit first and possibly upgrading later if you find yourself doing a lot of repair work or wanting better quality.
Also check out Louis Rossman’s repair videos if you don’t already know about him. His technique is fantastic. And he has links to all the tools he uses in the video description if you’re curious.
There are machines for extracting electronic elements of computer equipment, for example, circuit boards. After the automatic removal of components, manual sorting takes place. Then the parts are sent to a shredder or a grinding mill, which grinds them. I use rubbish removal birmingham services.They take all my rubbish for recycling.
Take them off one thing to then reuse them somewhere else, yes
