Hello I plan to build a computer soon and I have a problem. I don't know if this is correct but my ram runs on dual channel and my motherboard of course has 4 slots but they are different colors and I don't know which ones to use for my ram. Can you help me? Here are the parts
Ram http://www.amazon.com/dp/B007CCV1TI/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=1ILR1TVJ1M01W&coliid=I3C3VWA3CAN0NH
Motherboard http://www.amazon.com/dp/B00K872IT6/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1ILR1TVJ1M01W&coliid=I3XX2M1MWNWW4
They are color coded - like-colors for like-channels.
So, black and black, grey and grey.
Willl be in the Manual simple. but as you can see anyway on the motherboard its colour coded.
