Hi all,
I have 3 Network Interface Cards on my system, the one is on-board, and the other 2 are on a PCIe card (dual adapter).
When I am using certain VMs (qemu/kvm) I would like to isolate an adapter so only the running VM is using it, pretty much like I am doing with certain CPU core.
systemctl set-property --runtime -- user.slice AllowedCPUs=C8-15,24-31
I know I can isolate them using user.slice, but I haven’t been able to find a proper guide on how to.
And, yes, I know about device pass-through, but unfortunately, IOMMU- groups do not help…
My system:
System:
Host: wizzy-manjaro-kde6 Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro Linux
Machine:
Type: Desktop System: Gigabyte product: X670E AORUS MASTER v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X670E AORUS MASTER serial: <superuser required>
UEFI: American Megatrends LLC. v: F21 date: 01/10/2024
CPU:
Info: 16-core model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP cache:
L2: 16 MiB
Speed (MHz): avg: 1704 min/max: 400/5759 cores: 1: 4361 2: 3164 3: 400
4: 400 5: 3165 6: 3818 7: 400 8: 4213 9: 400 10: 400 11: 3147 12: 3166
13: 400 14: 400 15: 400 16: 4743 17: 400 18: 4411 19: 400 20: 400 21: 400
22: 400 23: 3262 24: 400 25: 3164 26: 3164 27: 400 28: 3160 29: 400
30: 400 31: 400 32: 400
Graphics:
Device-1: NVIDIA AD103 [GeForce RTX 4080] driver: vfio-pci v: N/A
Device-2: AMD Raphael driver: amdgpu v: kernel
Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_wayland driver: X: loaded: modesetting dri: radeonsi
gpu: vfio-pci,amdgpu resolution: 1: 3440x1440 2: 1440x2560
API: EGL v: 1.5 drivers: radeonsi,swrast
platforms: wayland,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-manjaro1.1
renderer: AMD Radeon Graphics (radeonsi raphael_mendocino LLVM 17.0.6 DRM
3.54 6.6.32-1-MANJARO)
API: Vulkan Message: No Vulkan data available.
Audio:
Device-1: NVIDIA driver: vfio-pci
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
Device-4: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB
Device-5: Creative Sound Blaster X5
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api
Server-1: PipeWire v: 1.0.7 status: active
Network:
Device-1: Intel 82576 Gigabit Network driver: igb
IF: enp12s0f0 state: up speed: 1000 Mbps duplex: full
mac: 98:b7:85:01:e3:3e
Device-2: Intel 82576 Gigabit Network driver: igb
IF: enp12s0f1 state: down mac: 98:b7:85:01:e3:3f
Device-3: Intel Ethernet I225-V driver: igc
IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac: 74:56:3c:4b:74:7e
Device-4: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
IF: wlp14s0 state: down mac: c2:28:7b:ea:43:64
IF-ID-1: virbr0 state: down mac: 52:54:00:3d:8b:7c
Bluetooth:
Device-1: Intel AX210 Bluetooth driver: btusb type: USB
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: see --recommends
Drives:
Local Storage: total: 5.52 TiB used: 1.13 TiB (20.4%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SKC3000D2048G size: 1.86 TiB
ID-2: /dev/nvme1n1 vendor: Seagate model: XPG GAMMIX S50 Lite
ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 970 EVO 500GB
ID-4: /dev/sda vendor: Crucial model: CT2000BX500SSD1 size: 1.82 TiB
ID-5: /dev/sdb vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
Partition:
ID-1: / size: 448.43 GiB used: 22.55 GiB (5.0%) fs: ext4 dev: /dev/nvme2n1p2
ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/nvme2n1p1
Swap:
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme2n1p3
Sensors:
System Temperatures: cpu: 36.5 C mobo: N/A gpu: amdgpu temp: 33.0 C
Fan Speeds (rpm): N/A
Info:
Memory: total: 64 GiB note: est. available: 61.95 GiB
used: 37.06 GiB (59.8%)
Processes: 540 Uptime: 39m Shell: Zsh inxi: 3.3.35
NICs:
0c:00.0 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
Subsystem: Intel Corporation Gigabit ET Dual Port Server Adapter
Flags: bus master, fast devsel, latency 0, IRQ 24, IOMMU group 20
Memory at a1000000 (32-bit, non-prefetchable) [size=128K]
Memory at a0000000 (32-bit, non-prefetchable) [size=4M]
I/O ports at e020 [disabled] [size=32]
Memory at a1040000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at a0400000 [disabled] [size=4M]
Capabilities: <access denied>
Kernel driver in use: igb
Kernel modules: igb
0c:00.1 Ethernet controller: Intel Corporation 82576 Gigabit Network Connection (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 36, IOMMU group 20
Memory at a1020000 (32-bit, non-prefetchable) [size=128K]
Memory at a0800000 (32-bit, non-prefetchable) [size=4M]
I/O ports at e000 [disabled] [size=32]
Memory at a1084000 (32-bit, non-prefetchable) [size=16K]
Expansion ROM at a0c00000 [disabled] [size=4M]
Kernel modules: igb
0d:00.0 Ethernet controller: Intel Corporation Ethernet Controller I225-V (rev 01)
Subsystem: Gigabyte Technology Co., Ltd Device e000
Flags: bus master, fast devsel, latency 0, IRQ 38, IOMMU group 20
Memory at a1200000 (32-bit, non-prefetchable) [size=1M]
Memory at a1300000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: igc
Kernel modules: igc
0e:00.0 Network controller: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX210 160MHz
Flags: bus master, fast devsel, latency 0, IRQ 44, IOMMU group 20
Memory at a1400000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
IOMMU groups:
IOMMU Group 20:
04:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port [1022:43f5] (rev 01)
09:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Upstream Port [1022:43f4] (rev 01)
0a:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port [1022:43f5] (rev 01)
0a:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port [1022:43f5] (rev 01)
0a:06.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port [1022:43f5] (rev 01)
0a:07.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port [1022:43f5] (rev 01)
0a:08.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port [1022:43f5] (rev 01)
0a:0c.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port [1022:43f5] (rev 01)
0a:0d.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 600 Series Chipset PCIe Switch Downstream Port [1022:43f5] (rev 01)
0c:00.0 Ethernet controller [0200]: Intel Corporation 82576 Gigabit Network Connection [8086:10c9] (rev 01)
0c:00.1 Ethernet controller [0200]: Intel Corporation 82576 Gigabit Network Connection [8086:10c9] (rev 01)
0d:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller I225-V [8086:15f3] (rev 01)
0e:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6E(802.11ax) AX210/AX1675* 2x2 [Typhoon Peak] [8086:2725] (rev 1a)
