How to install a Custom ROMs on most Android Phones
I have noticed how many people on tek syndicate are still using the stock bloated rom that came with there phone. Using a custom rom is a much more enjoyable experience than stock and it can expand the lifespan of your phone. Usually updates for a phone stop around 18 months after the phone has been released. If you have an older device this could mean unpatched security bugs and a general feeling of having an outdated device even though it is capable of running the latest version of android.
Before we get started here are the risks involved in installing a custom rom:
Risk:
  • Chance of Soft Brick
  • Chance of Hard Brick
  • Voided warranty (If you restore it to stock the warranty is void again)
  • Loss of hair over broken device
  • Data loss
Here is a great video of bricking devices:
https://www.youtube.com/watch?v=F_PvIMuwfLM
  If you do anything to your phone using this guide:
* Your warranty is now void.
* I am not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at me for messing up your device, I will laugh at you.
To install a custom rom you need to do a few things:
  • Unlock your bootloader
  • Install a custom recovery
  • Backup the stock rom
  • Install a custom rom
All devices are different but I will go over most popular phones, I will start with the easiest phones and work my way to the hardest.
Easiest Devices:
  • OnePlus One
  • All Nexus devices
  • Unlocked HTC devices
  • Unlocked Sony Devices
Since I own a OnePlus One and I know many other forum members do I will start on this device.
OnePlus One:
Noob Method:
Since the oneplus one is so easy to flash custom roms to XDA member manudroid19 made a tool kit program that can do all of this with a single button click!
Download here!
Steps:
  1. Turn off phone and start it up again by holding down volume down and power (You should see fastboot on the phone screen of you did this correctly)
  1. Open the program in administrative mode (You need java to run the program)
  2. Click unlock bootloader with method one (Note: this will erase all data so backup first!)
  3. Once you rebooted you need to do two things:
USB Debugging - On your phone go to Settings > About phone > Tap on Build number 7 times. This will enable Developer options. Now go back to Settings > Developer options > Enable USB debugging
Disable CM Recovery Protection - On your phone go to Settings > Developer options. Then disable the 'Update recovery with system updates' option.
  1. Repeat steps one and two
  2. Click root
  3. Click flash a recovery (I highly recommend TWRP recovery but you can flash another recovery like CWM)
  4. Click boot a recovery
  5. Make a backup
  6. Reboot phone
  7. Download any custom rom, gapps or kernel you want
  8. Reboot to recovery (Volume down and power)
How to install any rom:
  1. Hit wipe and slide to factory reset (Won’t remove your data)
  2. Hit install
  3. Install in this order: 1. Rom 2. Kernel 3. Gapps 4. Super SU
  4. Reboot
  5. Enjoy the new rom!
 Nexus 6:
Lucky for us XDA made a video about installing custom roms on the nexus 6:
https://www.youtube.com/watch?v=zMkG29a5a1o#t=13
If you like written instructions XDA Member xBeerdroiDx made a writen guide and thats the general bases of this guide.
Normal Method:
  1. Download the full Android SDK (Scroll to the bottom of the page and click Download for other platforms then SDK Tools Only)
  2. Run the program and install only
- Tools > Android SDK Tools, Android SDK Platform-tools
- Extras > Android Support Library, Google USB Driver
  1. Open a CMD windows at type
Code:
cd Desktop/android-sdk-windows/platform-tools
adb version
  1. If it returned "Android Debug Bridge version x.x.xx" you installed it correctly
  2. On the phone:
- Go into Settings
- Under About Phone, you'll be able to locate your Build Number
- Tap Build Number until you are notified that you have activated Developer options
- Go into Developer Options, ensure it is enabled and check the Enable OEM Unlock box
- While in Developer Options, ensure the USB Debugging box is checked
  1. Turn off the phone and restart it with volume down and power
  2. Plug phone into computer and open a cmd window
Code:
fastboot oem unlock (Will wipe all user data on the phone, BACK UP FIRST)
fastboot reboot
  1. Wait for the phone to do its thing when rebooting once it boots back up turn it off and turn it back on and download any rom you want with gapps and super su. Then turn it off and then on again with volume down and power
  2. Open a in cmd window
fastboot flash recovery recovery.img (Download me HERE and rename me to recovery.img and place me in Desktop/android-sdk-windows/platform-tools)
  1. On the phone, use the volume buttons to scroll onto "Restart Bootloader" and hit power to select it. After it reloads use the volume buttons to scroll onto "Recovery Mode" and power to select it.
  2. Hit install
  4. Reboot
Reserved for future use
Thanks, very useful post. Helped me unlock my old Nexus phone that I am practicing on.
I honestly believe that learning how to use command line and ADB/Fastboot is a much better skill than telling people to use the toolkit.
I totally agree with you but I made this tutorial more towards noobs. Right now I am trying to make guides for all the popular devices and carriers.
+1
Using any Windows program is a last resort type of deal really, the risk of something going horribly wrong is real.
Much better to focus on how to do it proper, with ADB and Linux tools. An Android device runs Linux, Android is completely developed on Linux PC's, why would you hack it using anything else but Linux? Windows is fundamentally non-compatible with the large majority of computing device on the face of the earth and in space for that matter. If something goes wrong, and chances are substantial that something goes wrong when using Windows to hack into a Linux device, there is no way to repair it.
On my Xperia Z1 if it says unlock bootloader allowed =no on  the service menu does this mean there is no way at all to install custom rooms?
I will update the one plus one guide for the proper way tonight and add another device to the list. Pippy is your z1 a carrier variant.
Yeah I'm afraid so,  O2 in the UK.
For almost all nexus device I absolutely love the Nexus root toolkit
