Hällo Logan,
Greetings Form Görmännie.
I was wondering, what tools you chose to create the Zweihänder Sound. Do you use a Software synth or any special Hardware ? And if it's software, die you usw preset sounds or die you fidele the knobs to find your tone.
Stäi epique,
Funkzander
he uses fl studio to make music
This is weird... I commented on this yesterday... I thought, maybe I'm going crazy.
I use a lot of these sounds: http://tweakbench.com
hm, dissapearing posts....
not to un-common of an occorance on any messageboard.
