I found this to be a very interesting way of encrypting your drives, its a few extra steps in the process but, for people with Laptops or just want to fully encrypt your drives at home I think its a great way to go the extra mile in encryption.
https://www.linux.com/blog/how-full-encrypt-your-linux-system-lvm-luks
Security and privacy are two very important subjects, and everyone of us, in a way or another, has sensitive data stored on his computer. While you can consider pretty safe your data on a home computer, on a laptop (or any portable device) the situation is a lot different. You carry your device with you and don't want to loose all your precious data in case it is stolen or lost. Here is when system encryption comes in handy.
In this tutorial i will show you how to full encrypt your system using two linux native tools: LVM (for partitioning) and LUKS (for the actual encryption).
Here's the process in few steps:
1) Create luks partition
cryptsetup luksFormat --hash=sha512 --key-size=512 --cipher aes-xts-plain64 --verify-passphrase /dev/sda
Note that obviously you can use different settings for the luksFormat command; above it's what i usually use. After that you will be asked to enter a password for the encryption, it doesn't matter if it's not very secure now, because we will only use this device as random data generator.
2) Open the encrypted device: the command below opens the luks device and maps it as "sda_crypt"
cryptsetup luksOpen /dev/sda sda_crypt
3) Now we fill this device with 0s using dd and /dev/zero as source:
dd if=/dev/zero of=/dev/mapper/sda_crypt bs=1M
4) All the underlying disk appears now to be filled with random data, minus the luks header that we are about to override (you can take a look using "hexdump /dev/sda | less" command). Usually the header takes few Megabytes, but to avoid calculations and be rude we will cover the first 10 Megabytes of the disk. We will use dd with /dev/urandom as random data source this time:
first destroy the mappingcryptsetup luksClose sda_crypt
override the headerdd if=/dev/urandom of=/dev/sda bs=512 count=20480
5) We have now the disk full of random data. Now for the serious stuff. Just repeat steps 1 and 2 but this time use a very secure passhrase, because it will be the key to unlock your disk
6) Now we will use the device as physical volume...
pvcreate /dev/mapper/sda_crypt
7) Now create a volume group (i will name it "vg00" ) that will contain the physical device /dev/mapper/sda_crypt
vgcreate vg00 /dev/mapper/sda_crypt
8) Create the logical volumes. I usually use 4: one for root, one for the swap partition, one for /home and the other for a data partition, but this is obviously up to you. The "+100%FREE" options on the last line modifies the command to use logical extents instead of size, and to use all of the free remaining ones for that logical volume.
lvcreate -n lv00_swap -L 4G vg00
lvcreate -n lv01_root -L 30G vg00
lvcreate -n lv02_home -L 10G vg00
lvcreate -n lv03_data -l +100%FREE vg00
7) Now create the boot partition on a separate device, ideally an usb stick, and install grub on the mbr of this device. With this setup we both will have no clear partitions on our encrypted disk, and no chance to boot the system without the external device, which adds an extra layer of security.
Please rembember that encryption protects your data only on a pre-boot situation when the machine is not on. After you boot and decrypt the disk you will have no added protection. All you have to do now is to install your system as always, and enjoy full disk encryption!
