Dear Logan,
I have a problem with focusing on what I am doing like coding a website or learning a programming language. How can I manage my time so that the little time I do work I spend it correctly. Some days i spend eight hours coding and can focus and others I can't spend ten minutes working.
What are some way that I could spend my time productively? What do you do when you can't focus and slack off? Do you play games, go on forums, or try an find inspiration?
