How to feathercoin?
How do i start using feathercoin? i have the wallet program but i cant find any blocks to download. Plus what miner should i use?
Here is a link to the pool I use for feather coins it will have a link to cgminer but will also have a link to their forums showing what type of config would be best for you based on what hardware you're using to mine with. Hope this helps. http://give-me-coins.com/support/gettingstarted
Jaycob's link is my favourite. They also do Litecoin and Bitcoin if your interested. If your new to this is suggest getting "GUIMiner Scrypt" http://guiminer.org/guiminer-scrypt.html. That way you have presets already so you don't have to fiddle around.
