Just have JavaScript redirect anyone using IE to this page.....
I can't help but feel the urge of stopping IE from eating glue. That stuff is unhealthy man! And he is wearing a safety hat too. Those two do not mesh very well.
I second this do this for everything if someone comes to your site using ie just redirect to that
IE9 is usually fine for most things, that's usually as low as I will ever support. Thankfully, MS dropped support for XP so people will be updating. If you have a significant portion of your market which is located in China, you're out of luck though.
My friend made pretty much the same thing on his website, when he found out, that IE was stretching a specific image out of its aspect ratio. That was also the only reason he blocked IE from his website.
