How to "De-RAID" HDD's?
I have two 1TB Seagate HDD's that I scavenged from an old Alienware PC that were running in raid. I tried to run them on my new Motherboard, but it seemed to screw over the OS whenever I had them in the machine (Would display "Missing Operating System" after the first couple of boot ups). I'm 20348% sure that it's the RAID 0 Setup that's causing this, but I'm not sure how to "de-RAID" them. Help? I'm using a GIGABYTE GA-X79 UP4 motherboard.
It could be simply the drive boot order that gets jumbled in the BIOS when the motherboard detects the new drives. Make sure the old drive is first in the boot, then simply format/repartition the drives in Windows using the Disk Management.
Use another computer to format the drives via USB or an enclosure.
If it was a software raid 0 you need to tell windows that they were in a raid 0. There is no way do "de-raid" the drives other than copying the data from the running raid system to another drive.
I remember setting up the raid array outside of windows; Intel Storage Matrix, or something to that note.
RAID isn't carried over from motherboard to motherboard. It can't find anything because only half of data that it needs is present. Set up RAID on your new motherboard for those drives and reinstall windows.
