Is there a way (software?) to crop the screen to only use for example the middle 500x300 pixels?
Like underscanning?
i need this for a diy beamer i-am making with a overhead projector and LCD but the lcd is a bit to big.....
Like underscanning?
http://www.monitortests.com/forum/Thread-Custom-Resolution-Utility-CRU
This might help, I'll plug in my LCD and check.
edit: Nah, cant get mine to do anything interesting with that.
You could find an old nvidia card that keystone works on.
Grab X11 in ffmpeg, and embed it into a flat black jpeg and then stream it, open it on the other monitor in vlc.
Or use a virtual machine.
It is such BS with windoes desktop that you cant shrink the bastrd
what are you beaming?
i would guess it would be more practical to just adjust your software, or footage,
unless you need to like contain the actual desktop, and mouse
@moneylotion
i'd like to beam some games movies, browsing etc.
but a full dekstop would be much more usefull
streaming is not a great option
thank you for testing ;)
What is the graphics card, High end and you want to play AAA stuff?
well i want to use it on different computers but, the laptop on wich i'll be using it the most has a Radeon 6770m
So some light games and a bit GTA V
You could put it through a capture device of some kind, latency issues though.
Might be easier to get a different LCD that fits.
It might be worth playing with CRU, My monitor maybe just cant handle anything strange, Be careful with it.
i'll try CRU thank you ;)
