How to connect to WPA3?
Hi.
First of all, Linux Mint 22.1, Cinnamon
I have issues with wifi connection.
When I turn off on my router WPA2 and force WPA3 I cannot connect via regular interface.
I tried to boot from live USB Mint to check if it isn’t me messed something up in configuration, but issue persist
And yes, my hardware 100% support it. Laptop released two year ago. (Asus Rog)
So yeah… Can you help?
By entering the password. But your device of course has to support it.
Because you can’t see it or because of an error?
What is your NIC?
This should output you the network scan. If you can’t see WPA3 only network, you don’t support WPA3.
sudo iwlist wlp11s0 scan | egrep -i ‘cell|chan|essid|wpa|cipher|qual’
