How to connect my Home Theater System to my pc
so is it possible to add my old home thearter system to my pc so when I play games the sonud will come out of the surround system
the home theater system I have http://www.amazon.co.uk/Philips-HTS3164-Home-theatre-system-channel/dp/B0017KIWBQ/ref=cm_cr_pr_product_top
what audio options do you have on your PC?
well here is the motherboard I have at the moment http://www.amazon.co.uk/gp/product/B0054U7HIO/ref=oh_details_o02_s02_i00?ie=UTF8&psc=1
the  only option you have on your Home theater unit is the two RCA audio IN.  so your best bet is to use the line-out on your onboard sound card and connect it to your HT unit with a 3.5 mm phono to rca audio converter
so something like this http://www.amazon.co.uk/3-5mm-Phono-Stereo-Audio-Cable/dp/B000Q6LSVS/ref=sr_1_1?ie=UTF8&qid=1400701871&sr=8-1&keywords=3.5+mm+phono+to+rca+audio+converter
yep, good luck.
thanks for the help
