How to configure M.2 Max Current on ASUS WS WRX90E
I have a Corsair MP700 PRO SE M.2 2280 4TB that I can’t get my Pro WS WRX90E Sage to recognize.
It seems like somewhere in the BIOS I should be able to change a “Max Current” setting to 3 A for the M.2_1 slot, but for the life of me I cannot find this option anywhere.
I’m using the BIOS version 1106
Does anyone know how I can find this setting or otherwise get the Motherboard to recognize my Corsair M.2 drive?
Wut. 3A at 12V? Where does this requirement come from?
I know the Pro WS WRX90E-SAGE SE BIOS inside and out. That setting does not exist.
When you say it is not recognized, do you mean to say that it simply does not populate in either the NVMe section in BIOS or Windows Device Manager?
I definitely may have been misled.
Yes, it doesn’t populate in the NVMe section.
Windows has not yet been installed
Enter BIOS and go to Boot → Boot Configuration and enable / verify enabled AMI Native NVMe Driver Support. Reboot if required and check again.
MP700 PRO SE is an E26 drive and M.2s supply 3.3, not +12.
36W M.2 drives would be hilarious indeed.
Bit barbecue anyone?
The AMI Native support is already enabled.
Is there another setting I should check?
