I need to change the built samba credentials that I saved to auto login for centos. Basically centos can connect without installing samba to windows shared folder. I did a clean install of windows and now it is trying to connect with the old credentials. I need them updated.
I fixed it by changing the ip to the samba share server. It now allows me to enter new credentials. I just wish I could figure out what the issue was.
