So, I've installed Debian 7 with gnome 3 (it's freakin awsome). And nearly everything is working perfectly. But when I look at my hardware info through the commandline under: dmidecode it states that my two sticks of ram are on 900'ish MHZ. But my stock clock on my ram sticks is 1866 MHZ. With googleing I only found suggestions for changeing the clockspeed in the BIOS. But it is, and was always 1866 MHZ in the BIOS. I've changed in the BIOS the standard profile to automatic, with 1866 MHZ speed, but it still stays the same.
My Hardwarespecs:
Asrock 970 extreme 4
Crucial tactical 1866 mhz cl9
AMD FX 6300
Sapphire HD 7870 XT
XFX 850 watt PSU
120 gb SanDisk Extreme Pro SSD
I can live with it. It's still faster than windows. But it would be such a waste ...
Thanks for clearing it up. Only in the BIOS. I just thought if there is no other way, it has to happen maybe in linux? But luckily it was such a stupid mistake :).
It's not actually divided across the channels, but split across rising and falling clock edges. The DDR clock is 900 MHz on the rising voltage edge, but data is clocked on the falling edge of the pulse as well, so the data rate is double the clock speed.
