So my ISP has been blocking a lot of websites recently and I need some help on how to access them. Suggestions?
Why have they been blocking them? Any ideas?
You could use a VPN. That is what I'd do. There are a number of free ones available although the paid options are usually much better. They are reasonable too.
just to name a few
vpn: best all-round solution, most cost money 5-15€/month, probably requires you to install a software, excellent speed, will give you access according to the laws of the country the vpn provider is located in. I recommend Netherlands, Luxembourg, Finland & Switzerland.
webproxy: easy setup, mostly free, just copy-past an ip and port into your browser settings, mediocre speed, do NOT use it to log into important accounts.
tor: download tor-browser-bundle & you're pretty much guarantied to penetrate censorship, slow speed, free, provides more anonymity than most other solutions.
ultrasurf: easy setup, requires software(doesn't work well on linux), free, breaches allot of censorship measures, mediocre speed.
If your ISP is lazy and just removed the websites from their DNS look up you can use another DNS service, like OpenNic or Namecoin, try installing the World IP geo Firefox-addon.
I'm not sure if it even makes sense but try changing your DNS to 8.8.8.8
Some websites that wouldn't load started loading when I changed mine.
