Ok so guys before you rage I do game on my main windows rig. Anyways I have my main rig and I was interrested in doing a windows/osx dual boot. I have parts that are suppose to be compatible with apple ex Gigabyte UD5H and a 3570k so I just really need instruction on how to do this.
Thanks!
Welcome to the world of hackintoshing!
Take a look at http://www.tonymacx86.com/333-building-customac-buyer-s-guide-february-2013.html There you can find different parts that usually works straight out of the box. Building a OS X compatible computer today is extremely easy, just make sure you have a compatible wireless card if you're planning on using that. You can build one yourself (Google "Do it yourself Apple Airport") or buy one that you know is compatible.
Other than that, remember that you need another Mac or a virtual machine running OS X in order to create a bootable USB installer. You do that by using UniBeast. After you've completed the installation, use MultiBeast to install the correct drivers for your hardware.
Remember to install OS X before you install Windows when you are going to dual-boot.
Good luck, I'll post some useful sources down below that might help you further, otherwise don't hesitate to ask.
http://www.tonymacx86.com/61-unibeast-install-os-x-mountain-lion-any-supported-intel-based-pc.html
http://teksyndicate.com/forum/mac/hackintoshing-and-you-guidefaq/130968
