How To Block ISP Throttling in Linux Ubuntu?
Iv'e noticed alot recently that my internet connection is running VERY slow and barely can run a single youtube video -_-. Sometimes I will have like 3 youtube tabs open in 1080p just fine and sometimes one music video on low will give me trouble. Also its like 11:00 at night so its not like theirs much traffic.
http://teksyndicate.com/videos/tek-0048-major-isps-suck-harder-every-day
Here logan shows how to stop it in windows and mac but not in linux. How do I do it in linux ubuntu?
If you want to drop the TimeWarner servers, here's the command:
iptables -I FORWARD -s 192.168.1.0/24 -d 206.111.0.0/16 -j DROP
Just change the 192.168.1.0/24 part to the Network appropriate to your home LAN.
the above command has to be sudoed
and after that it has to be saved, I think in Ubuntu it's just
        #  iptables save
, but I don't use Ubuntu so someone please confirm.
didn't work? says is unknown and kernal may need upgrade.
if you type in terminal:
      $  sudo su
then enter password
and then
     #  iptables -L
do you get anything?
