So I’m looking at setting up 3 major utilities for my network.
- pfsense
- Pi-Hole
- FreeNAS
But I want to use my machines that I have available the best that I can for the processing power I have available. And, since I want to generally never ever fuck with these machines, or machine, once they are in place, in my opinion, the more powerful box and less machines total used the better.
Right new I am planning to run PFSense on my Mac Pro 1,1. I wonder if it would be possible to run pi hole alongside it on the same machine? What about freenas? Could I run them in VM’s and still route traffic on the 2 built in NIC’s?
ATM I don’t have any PCIe NIC’s on hand, so I am relying on the 2 built in. I have checked, its 2 separate NIC’s.
So what do you think? Could I run all of these systems on one box? If so, how?
Specs of the mac pro just in case someone needs to know
CPU: 2X Intel Xeon 5150 @2.66GHz (2C2T)
RAM: 16GB 800MHZ FBDIMM DDR2 (I think with ECC?)
2 X Intel gigabit NIC’s (can’t find name, ET something)
16GB boot SSD and maybe a hard drive for caching sites
Edit: Oh, also, what happens to be the worst spec to run pi hole on? Could I use something like a pentium 4 if I had one loose?
