How should i upgrade my rig?
So, my friend sold me his rig since he is moving away for extremely cheap, and i know i need to upgrade it a little but im not sure what exactly since i need to buy since i still slightly new to it. Im looking to play most games on ultra like BF4, Arma 3 and Etc. The specs are as followed
CPU: Intel i5-2500k 3.3/3.7 ghz
Mobo: GigaByte GA-Z68X-UD3H-B3
Ram: Kingston HyperX Blu 8GB (2 x 4GB) DDR3 1600
GPU: MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB
Hard Drive: Kingston SSDNOW V+ Series 64GB
DVD Drive: Lite-On iHas 124
Power Supply: Power PC & Cooling Silencer Mk III 400W Modular Power Supply
Case: Antec The Hundred Two
Any ideas?
Well, this highly depends on your budget. The first thing that I would upgrade would be the GPU. And depending on the GPU you select, you may have to upgrade the PSU. Everything else looks great. Maybe add a CPU cooler and a larger storage drive.
He too out his HHD so i have a 1TB one lying around some where, but my budget is flexible especially around the GPU since i know thats the part you should invest most of your money in. but im open to ideas aslong as the pricing for it is reasonable and not too crazy.
What resolution is your monitor? Also, can you give me a definitive budget? This would help out a lot. What is the max you're willing to spend?
Assuming you're gaming at 1080p, I would recommend either a R9 280X, R9 290, or a GTX 770. I think you'll also need a new PSU if you go for one of these GPUs. That 400w PSU would be cutting it close. I would at least go for a quality 550-650w.
GPU:
http://goo.gl/BabDaZ
Or...
http://goo.gl/SIqllZ
PSU:
http://goo.gl/x10otk
around $700 i can stretch it a little more if i have to also. but my screen is 1980x1080, but yes i want to game at 1080 and ultra is possible.
This should handle your needs well...
http://pcpartpicker.com/p/2bT4h
If you want, you can also wait for the non reference R9 290s to come out. I'm sure they may even be a better deal for around $400-450.
what do you mean by non reference?
A graphics card with a different cooler than the reference design. For example:
Reference - http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121769
Non Reference - http://www.newegg.ca/Product/Product.aspx?Item=N82E16814121779
Get a new R9 280x and a 120gb ssd for more storage. Those two upgrades will give you the most noticeable and greatest performance increase.
