How much power is safe to use on 6900XT using Igor’s Lab More Power Tool? I have an AMD Reference 6900XT with 2 x 8pin connector. PSU is 800W Titanium with single 66A 12V rail. I have a custom watercooling loop using Alphacool blocks with 360mm x 28mm and 240mm x 60mm radiators. My temps are great, usually between 40⁰C and 60⁰C while gaming, and 70⁰C maximum Hotspot temp while benching with heat saturated loop. I have upped the gpu power to 350W and that allowed me to score 20,800 graphics in Timespy with 1075mV and 2625MHz clocks. How much higher can I safely go with the power?
Varies card to card, probably wouldnt push it really any higher as if you brick the card GL getting another one
