The preset amount is 80mW and it goes up to 200mW, but I imagine that would cause issues or shorten the life of the router, so how high can I safely go?
It would be nice to make the signal a little stronger to make my shield happy when streaming games. Thanks in advance!
increasing the power will only decrease the life, if it also increases the heat. According to a study done by ASUS a few years back, computer parts will lose about half their life for each 5 deg (Celsius I believe) they increase in temp. So keep it cool and you should be good to go.
But keep in mind this wont necessarily increase the range or the speed, it will just help it break through interference. Yes, you may gain a few feet or a extra couple of kbps, but its only because interference isn't as high, not because you put more power through it.
the chips of the n66u and ac66u CAN output 500mw, but it's completely unnecessary. they are safe too 200, If they weren't safe the option wouldn't be there.
