How much more cooler is with liquid?
i'm talking about running it max for renders for max 24hrs continuous;
780ti, i7 4770k; over clocked if possible;
would it be better to run on liquid?
or would my components last as long as the ones with air?
and why
oh, i'm talking about 3 120mm thin rads.
i live in england if that ever matters;
HEY! i can stick the rad outside when it's snowing! extreme over clocking!(never gonna do that though...)
Water cooling components usually keep the CPU 5-10 C cooler than air-cooling heatsinks depending. How long they will last is kinda irrelevant as most CPUs will last longer than you will use it for.
The other thing to consider with water cooling is it evacuates heat out of the case immediately and therefore doesn't heat up other components.
It depends which cooler.  Soime 360mm rads just can't be beat.
However, air cooler are usually more reliable.  I suggest the Noctua NH-D14
Go with an air cooler like a 212 evo or Noctua..., i forget the number, for a really stable lower frequency overclock. There's next-to-no maintenance, you have to blow it out like twice a year to keep dust off, and no chances for leaks.
Liquid cooler will keep your CPU cool allowing you to run more voltage to your CPU to get higher frequencies while still keeping the unit cool. Depending on what liquid cooler you grab you may run into maintenance issues like refilling the reservoir, cleaning the system (Some of the fluids with dyes in them for pretty effects can gunk up the system and lower pressure and flow), and possible leaks. This is just depending on what you go with as to what kind of maintenance you may run into down the line.
Also, air coolers are just a fan or two blowing on a hunk of metal. If they break you just have to get a new fan for like $10-$15. With water coolers you have the pump which can be pricey, reservoir, radiator, and all of the tubing. There's differing chances of fault with all those different pieces, but generally if something goes wrong with a liquid cooling solution it'll be more expensive.
So pros and cons to each, if you want a more aggressive OC go with liquid, if you want a lower frequency OC but with low maintenance and high reliability go with an air cooling unit. Just for the love of god replace that shitty stock cooler.
Water can be low maintenance, some people with large reservoirs don't refill for a year at a time, and you don't have to clean the system if you just use distilled water. And temps over a 212 or Noctua are really good but, aio's are a slight improvement but its a bigger gain on a full custom loop. Especially on the graphics card. Which usually drops temps from 80c at load to about 40c on load.
