How much cooler would it be?
Well I have an A10-5800K and I want to replace the thermal paste, the only reason why I want to do that because I saw one of Linus Tech Tips Videos on Thermal Paste Show down or something lol and the one that won was the arctic mx-4, so I'm like, okay I'll get that. And he says that there is a near 15 degree drop when just switching just the paste. Will I get the same differnce or what? Because I'm just fine with some thing with like a five degree drop.
Different thermal pastes can make a difference but personally I have never seen much difference. The heatsink usually matters more. Some thermal paste is conductive. So I recommend watching Logan“s video on how to apply thermal paste if you are a novice and going to use one of those.
here is a link
https://teksyndicate.com/videos/how-apply-thermal-paste
Best method I have found is using an old credit card. That, and making sure your heatsink is on nice and tight. Not too tight, but that is up for you to decide how tight you should screw it down. Too bad you can't use a torque wrench on PC's lol. Would make these things easier.
