As the title says this is a question as to how many watts will my new system run. These specs aren't final but it is the sort of specs I want for the price:
Asrock 990FX extreme 3 Motherboard
AMD FX-8320
MSI Twin Frozr GTX 770 in SLI
Crucial Dominator GT 8GB 1866 RAM
Coolermaster Hyper 212 EVO.
What power supply would you reccommend for me, I had a look at a Corsair HX850 PSU for £120. Should I buy this or can I get any cheaper power supplies that can handle this system. Bear in mind that there will be some light to medium OC on the CPU and GPU.
I dont recommend the Asrock 990FX extreme 3 for overclocking i am useing one as a temporary mobo (2 asus mobo's i had where fulty) it has a 4+1 vrm and the mobo is thin it overheats at stock with my FX8320.
Knowing that the rest of your system will take around 100Ws(fans and all) probably I'd say an HX850 is enough if you're not OC'ing to the extreme, as it is exponential not linear.
That is true TDP added by the manufacturer is usealy the thermal cut out point in which a cpu will start to throttle its self under normal conditions to operate with in its limitations ie running at stock before overclocking.
You can drastically change the TDP by adding better cooling and overclocking pushing up the power it uses.
I definitely dont reccommend overclocking on that extreme 3 mobo it just isent beefy enuff for even a small overclock on a power hungery 8 core
