I am trying to set my truck up for overlanding. I have a LiFEPO4 battery, and I’d like to add a port that will let me charge my laptop via USB-C. The laptop charges at 65W + watts.
What I don’t understand is how many volts USB-C PD should be. Looking at my laptop’s power adapter, the output is listed as 3/5/12/20V (with the respective amperatures to get to 65 watts).
So, to roll my own USB-C PD, what voltage do I need to be at coming off of the converter?
The voltage is negotiated so you need an adapter. If your LiFEPO4 battery is 4S or you have a 12v converter then you can just use a standard power port adapter.
I’d get something that supports more than your laptop requires. When these things run at their limit they can get pretty hot.
