How many fans do you have in your case?
i have 8x140mm fans with with white LED.
4x140mm
  • 1xNoctua NF A14
  • 2xFractal Case fans
  • 1Corsair fan
I Use 1 Fractal on the back of my case, on Fractal in the front of my case, in front of my H110 on top and on the bottom I have the Noctua. Because I have a HDD cage blocking the bottom so I threw the Corsair fan that i got with the radiator in push pull with the Fractal fan. I plan to change the front Corsair and Fractal fan with Noctua fans.
2x140 and 1x120 as well as one 120 in the psu that sometimes turns on with load.
All Noctua aside from the psu which I am pretty sure is a Sanyo Denki.
i have 3 XIGMATEK FCB enchanting out the top. One out the back 3 bringing fresh air in from the front,
The last one is my cup heat sink.
honestly sitting next to my computerI  it like  sitting next to an AC unit  ..... LOL
2x200mm and 2x140mm
Will be looking at 2 more 140's and 1 more 200mm. My computer runs cool :3. Atleast when its not 45 degrees outside :\
i have 4x 120mm cougar fans doing push pull on my 2 120mm  radiators
and i have 6x 140mm cougar fans, 2 front intake, 2 topside exhaust, and 2 on the cpu heatsink.
and 2x 120 mm corsair fans. 1 on the cpu heatsink and one exhaust out the back.
and 2 smaller fans im not sure of for a total of to blow on my video cards RAM and VRM
14 fans.
2x 120mm sp fans(H80i) + 4 120mm case fans
3x 120, 3x 140, and a 120 on the cpu cooler, so 7.
6x 120. Five on the case. One on the CPU Cooler
2 x 200mm (NZXT), 8 x 140mm (Noctua)
2 x 230 azza 1x 230 bit fen 4x 120 corsair sp for rad 4 x 120 corsair airflow led bling and 1 x 120 cougar just to step into when i need it .
These are what my case came with
1 x 120mm Front Red LED Fan
1 x 120mm Rear Fan
2 x 120mm Top Fans
1 x 200mm Side Red LED Fan
Then put Asetek 510LC(yes it is crap compared to what most everyone has here) on the rear fan and added a red led 120mm push fan
so 6 fans
then what ever is in the His Ice Q 6850 and what ever is in my 850 Raidmax 80 Plus Gold Power Supply Yes this is way more than I need but I don't know how I am gonna upgrade this thing later..
Fractal Design R4
5x Fans total.
Case: 3x AF140 140mm (2x front, 1x side) all intake. No rear fan, removed spare blanking plates. Blocked top vents with pre-installed covers.
Heatsink: 2x GT-AP15 120mm on a NH-D14
Keeps things cool enough with next to no noise on 7v case fans and 12v heatsink.
4 fans total.
  • 1x200mm (front)
  • 1x120mm (rear)
  • 2x140mm (HSF)
10 fans:
4x120mm on my H100i in push pull
4x120mm case fans 2 of which have blue leds
2x140mm case fans.
