How many amps does the AMD R9 290 need?
I can't afford any other power supply except the Seasonic G-550 80+ Gold, it has 45 amps on the +12V. Will it be enough for the R9 290? I won't be overclocking the card. The R9 290 only uses around 275 watts and the CPU I'm using will be the AMD FX 8350 which uses 125 watts, so that's 400 watts for both the CPU and GPU, I won't be overclocking any of them.
Will the power supply be enough for all of this? Here are the specs:
AMD FX 8350 = 125 watts
Sapphire R9 290 = 275 watts
Cooler Master Hyper 212x = ?
AM3+ Asus M5A99FX PRO R2.0 = ?
G Skill Ripjaws X 8gb (4gbx2) = ?
ADATA XPG SX900 128gb = ?
Western Digital Caviar Blue 1tb = ?
Two 120mm bitfenix fans = ?
http://pcpartpicker.com/part/rosewill-power-supply-capstone650m
for the same price you can get this and that will for sure power all of your system.  There is also a 750watt version
