Just a little competition for everyone. The Goal is to make a PC that can play Witcher 3 and Shadows of Mordor, with a playable frame rate. Setting have to be High or above with no AA. 1440p. You can only use Online stores and you have to spend the least amount of money possible.
http://pcpartpicker.com/p/KLWYK8
Something like that would work. Could cut out the SSD and CPU cooler if you want to save more but I'd strongly recommend you didn't.
specify your idea of "a playable frame rate", Never dropping below 60fps?
thankyouplease
lets say minimum frame rate of 35.
I know if we did 60 would have to be a 980 or similar so 35 we can use some cheaper cards
Then I'd say pretty much the same as DerKrieger but replace with a 285. 250Gb HDD for storage.
I wouldn't recommend this as a real system choice.
