How long will it last?
Whats up guys,
So basically I'm in the market for a new high end gaming rig - Looking at about 1800$ for the PC only.
How long will this setup (i7 4770K, GTX 780 Ti, 16GB ram, high end mobo, ssd, sick cpu cooler etc.) last me?
Is it reasonable to think ill get about 5 years out of the thing when doing nothing but maybe OC'ing down the line?
Obviously I'm not expecting Ultra settings at crazy res's for 5 years, more like just being able keep up with games decently for 5 or more years down the line.
 Logan do a video on this! "How long will your High end gaming PC last you"  :wub:
 Thanks in advance guys.  :)
Basicly i would say yes, it will lasst you for those 5 years, only maybe the gpu needs a upgrade, cpu etc will definitely last you, but the gpu is allways hard to say. for a gpu im allways a bit carefully , i would say arround 2/3 years maybe.
But you could ask your self is it worth it?
For example a FX8350 with a Asus Sabertooth. and R9-290 or GTX780 will also last you for3 years. and that will cost alot less.
or an intel i7-4820K with a GTX780, or R9-290. and maybe later on buy a second card for sli/CF.
My point.. a GTX780 ti is not worth its money.
In my experience good-quality consumer-grad mainboards either die within 2 weeks or last 4years of continues non stop use. (you do the math for your use-scenario)
processors is hard to say, but in general the higher the temperature the shorter the life span, Smaller transistors (i.e.: low nanometer numbers) probably also shorten the life span.
The haswells have integrated voltage regulators so there's no telling how well those will withstand overclocking/cooking
My guess is that the processor will definitely last 5 years of intense gaming if you keep core temperature below 60°C for 95% of the time
Graphics cards usually don't last that long, most of mine died after 2,5-3 years, but i like to over-clock medium range GPUs to reach premium speed at lower cost.
I haven't had dead Ram, but I may be an anomaly in that regard
As final advice: DON'T buy premium stuff to last 5 years: it's way to bad price/performance:
Buy medium range stuff to last 3 years. Computers aren't an investment, they're temporary compute machines that you'll discard in a few years. If you buy parts for 900$ now and in 3 years can spend the other 900$, you'll get way more processing/gaming power for your money and you'll have 2 pc's instead of 1.
