How is this build
look at my cooler and tell me if this will fit with out taking the case off or any other fans also my gpu will be 280x toxic and http://pcpartpicker.com/p/2THk8 also will ther be any bottleneck tell me if there is anything wrong with this build
this case supports gpu´s upto 16inch so the 280X will fit, about the Noctua NH-D14 i think this one will also fit, but it could be that you have to sacrefice the side panel fan.
thats what i thought also do you think i needed to take the 2 120mm off at the top
no those on the top will be fine there.only i would recomend to buy a better psu by the way. but thats up to you ☺
umm which MOBO would you recommend.i thought all psu with 80+ bronze are good
a bit depending on your budget,  coolmax is not known as the best psu brand.
About the motherboard, i would personaly go For the Msi Z87-G45 gaming mobo, it has a nice layout, great feutures, and a decent 8 powerphase and digi vrm.
The gigabyte board would probably also not that bad, but i have to say, i didnt have the best experiance with gigabyte boards in the past, that why i personaly avoid them a bit, i thought that the board you had selected, had only a 4+2 powerphase, but i looked wrong.
anyway: http://pcpartpicker.com/p/2U13l
okay thanks for your help
