How Is This Build
http://pcpartpicker.com/p/vYdM
http://pcpartpicker.com/p/vY9I
or you can have a 670 for the same pice as your 660ti
http://pcpartpicker.com/p/vY9v
why do u have a 160gb hd in your build?
I changed it. How is it now? Tell me if it needs other changes max $970
You can get cheaper RAM that can run at 1866 and takes 1.5v..
edit: you changed it, but 1866 RAM is only like $42
Where?
if amd is an option http://pcpartpicker.com/p/vYvr
8 core with 7970
if you want i5 then http://pcpartpicker.com/p/vYNl
and if you are willing to change your build but keep the i5 http://pcpartpicker.com/p/vYQM
I'd just take out the SSD and use that money for higher quality stuff all around like PSU and motherboard.
