I really like it, has anyone here tried/recommended it?
It sports an avago 9800 lazer sensor so it may not be as crisp as some optical mouses out there, if you are fine with that fact then go for it :)
It really costs more than it's worth and has a sensor that is inferior to ones in Zowie mice, G400 or DeathAdder.
I have it. So far its been great. but yes I agree on the price is higher than it should be.
What would be the biggest difference between the M65 and the Raptor M40 then? cuz I do believe the M40 is priced lower
