How hot should my processor be?
So I have an AMD 6300 with the stock AMD cpu cooler on it. I can smell the heat is that Bad? I have the stock case fans as well. Should I upgrade to a Hyper 212 EVO. when I put my hand on the side of the case it feels a little warm. How can I reduce the amount of heat.
do you know what temps are normal for a 6300 stock cooler?
im only 12 and spent a lot of money on my build. If it breaks my parents will kill me.
please help
i built my computer btw.
I dont know what the "normal" but the max is70c socket, 62c cores. And if you dont know what temp your CPU is look in your BIOS or whit a side programe like CORE TEMP
The smell will ether be the thermal paste cureing or there is protective plastic on the heatsinks on the motherboard you may have missed (thay love to put that plastic everywhere)
What temps are you geting?
Sorry, you can "smell" particles with a greater heat energy...?
At the league of legends client Im getting about 60 degrees Celsius. Is that good? Sitting alone with nothing open but AMD overdrive i still get about 60 degrees Celsius. should I get a new cpu cooler?
My degrees are 60celsius. Is that bad?
Did you remove ALL plastic off the Heatsink?
No 60c is hot i'd grab a 212 evo the stock heatsinks are like a asthmatic blowing air through a straw at your cpu.
i think he didnt remove the plastic. its a good idea to get a 212 anyway
Ok. I'm a little scared though. I do not know how to install a hyper 212 EVO. what would be the normal temperature for my cpu. Is there anything else I can do?
It's a long process but it is relatively simple, just follow the instructions.  I have a Hyper 212 evo and with my 3570k @4.3 I hit a maximum of 63c while running Prime95. It idles at about 30c.
Also if you want to keep an eye on your temps I recommend a program called HWmonitor
