I am currently formating my new cavair black 1tb and I want to transfer everything that is not important to that drive from my 120gb hyper x.
It's as hard as going to the files, pressing Ctrl + A then Ctrl + C then go to the new drive and press Ctrl + V.
Unless you meant something else...
Is it really that simple? I have never had more than one hardrive in a system.
Ever used a flashdrive? Same basic concept. Except the HDD has 1 TB of space and the flashdrive (usually) has only 16 GB.
Yes it is that simple :p copying files to different drives is really no more complicated than copying and pasting files to different folders on a single drive, or to a flash drive as bassfire mentioned.
You spelled my name wrong.
