So I am looking at a Cowon Plenue M PMP and I used to have a Cowon S9 so I know their stuff is good but I am curious about just how good some of these components really are.
here are some of the specs relating to the Sound:
- 24bit/192Khz HD sound
- Highest Performance Burr-Brown PCM1795 DAC
- SNR 120dB, THD+N 0.0007%, Crosstalk-132dB, Output 2Vrms
- High Precision TCXO
- 3Ohm Output impedence
- 140 Volume Levels
Supports the following formats/codecs:
- DXD
- DSD
- FLAC
- WAV
- AIFF
- ALAC
- APE
- MP3
- WMA
- OGG
- WV
- TTA
- DCF
It has Cowon's JetEffect 7, an ARM Cortex A9 1.2Ghz Dual Core CPU, an AMOLED 3.7" 16M Color Display.
The chassis is a High-strength Metal Unibody
It has 64GB High Speed Internal storage
a MicroSDXC slot, Optical Out, a Stereo Level Meter and a Matrix Browser.
You can also plug it into a PC and use it as an external Sound Card/DAC for the PC via USB.
The microSD slot supports up to 192GB.
List Price: $799
Is it worth that price?
