How does this build look?
Hey everyone here is the build, Tell me if there's anything wrong or I could improve something.
CPU:              AMD FX 8320
Motherboard: ASUS M5A97 R2.0
Heatsink:        Coolermaster 212 evo
RAM:              8GB DDR3 of whatever brand is cheapest on black friday
GPU:             His IceQ radeon hd 7870 ghz edition 2gb
Psu:              XFX core edtion PRO550W
Case:            Corsair carbide 200R
I think thats everything :) Tell me how it looks.
whats it for? if gaming then yeah should run perfect i think the 8350 is better though and around the same price?
i personally would get a better GPU and a lower CPU but still 8000 Series
The 8320 is 50 bucks cheaper than the 8350.  It is just under clocked.  You can overclock it easily with a Hyper 212 Evo.  I would get a mobo with a 990fx chipset.
Looks good.  I don't expect to get much of an overclock on that board, though.  Something like
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131851
would be a lot better due to a 6+2 digital power phase design, and a better chipset.
For RAM, just make sure it's over 1600mhz.
