Building another PC looking for some feedback.
Using a Corsair 900D Case. (Not on the list)
UPDATED with diffrent GPU ( http://pcpartpicker.com/p/NwU3)
Looks overkill, But I like it. I would say though, drop whatever you have to throw in a 7970 or 680 over a 670. As long as you're going big, better to go home.
Should i stick with EVGA or do you think MSI/ Gigbite is better?
if you gonne do only gaming the a HD7970.
if there is a reason about youre cuda needs, then stay with the GTX680
Is there a reason for 2 monitors?
For Sony Vegas Editing.
7970 ^^ i readed it does a very good job in vegas.
Small changes.
http://pcpartpicker.com/p/NxC5
IPS panel amazing quality monitors.
LGA 2011, might just be me but I refuse to suggest LGA1155 for a higher end build like this.
Zowie mouse will look/perform a bit nicer and is plug in play if that's your thing like it is mine.
ADATA SSD es better.
You can fit the dominator ram in if ya' want. I probably would if I were you too, it's beautiful hahaha.
I was going suggest a different/higher watt psu, but honestly I love corsairs super high quality shit too.
Idk if you'd really need the cooler but fuck it why not.
I aimed this toward the future kinda.
http://pcpartpicker.com/p/NxNN
